If you have water leaking in when the AC is not in operation and it is raining and you are sure the gasket is adjusted properly and the drains are all open, then I would guess you have a hole/leak somewhere where the base pan meets the indoor coil. These units are designed to be weather tight and should not need to be covered when its raining.
Retired Navy
2016 Flagstaff 26 FKWS
