Backup Light Replacement
Hello, I have a 2011 Lexi 255 GTS with a backup (reverse) light not working. I see prior posts that indicated the way to replace the light is to push the sealed light into the interior of the molded plastic bumper, rubber grommet and all. Before I go down that rabbit hole only to find that there is no way to retrieve the old light assembly and have, in the process, gained a nice round hole in the back, would any community member please confirm that is the correct approach? If not, what would be the way to replace the backup light? Thanks in advance for your guidance!
