Old 12-03-2023, 02:13 PM   #1
Crack in the fiberglass cap over the cabin.
Hi all. I just found a crack in the fiberglass cap that is over the cabin on passenger side. It is small and in the corner above the door frame. I have no idea if its been there for a long time, I am the only owner of the motorhome since bought new in 2013 and I didn't use it a lot for the past 3 years. My question is what should I do ?
1) Wait and see (actually it is 2 inches long).
2) Drill a whole at the end of the crack to prevent it from spreading and seal with ProFlex RV.
3) Bring the motorhome to a specialized center to have it repaired or replaced.
4) ???
Thanks in advance for your suggestions/comments.
ID:	295435   Click image for larger version
RFLLambert.
2014 Lexington 265DFS.
RFLLambert is offline   Reply With Quote
Old 12-03-2023, 02:48 PM   #2
Kanadian Kamper
kenandterry's Avatar
Just to do some research……see if you can find a good marine repair Center that works on repairing fibreglass hulls on boats, and get their take on what to do.
Then, see if you can find an automobile repair Center that works on Corvettes. Again, they’d know best how to deal with fibreglass repair.
It might be DIY, but I’d check around.
BTW….I have the same fibreglass cap on our Sunseeker, so I’d be interested in what you find……just in case.
ID:	295443   Click image for larger version
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is online now   Reply With Quote
Old 12-03-2023, 03:35 PM   #3
I would drill and seal, wait and see, then follow kenandterry's advice if it gets worse.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 12-04-2023, 03:33 PM   #4
Thanks for your comments. I drilled a hole and sealed with ProFlex RV. Now I will wait until next long trip to see what happens with road stress. I'll give you some feedback after that.
RFLLambert.
Old 01-02-2024, 10:52 AM   #5
After a trip from Florida to Montréal, around 1800 miles, everything seems to be stable. I will continue to monitor the crack and will only come back to you if the situation deteriorates.
RFLLambert.
Old 01-02-2024, 02:15 PM   #6
Thanks for the update, hope the fix continues to work.
crack, fiberglass
