Old 12-05-2016, 03:27 PM   #1
Does 350 lbs added cause reduce gas mileage
I just purchased a 25.5 Lexington with the Ford V10. The previous owner added granite counter tops and heavy rock flooring. This adds at least 350-400 lbs. My gas mileage at 60mpg is 9.3mpg. Would I get better mileage if I change the counter top and flooring to a light weight material.
Richard Kanehl
2007 Lexington Class C - 25.6
Leesburg FL.
RKanehl is offline   Reply With Quote
Old 12-05-2016, 03:58 PM   #2
Possibly, but probably not enough to notice. At 60mph, air drag is more important than weight.
2011 Traverse LT, 3.6L, FWD
Old 12-05-2016, 04:17 PM   #3
Add 350 more and drive around. See if it changes anything. (It won't).
aeblank is offline   Reply With Quote
Old 12-06-2016, 07:03 AM   #4
Send a message via AIM to NoviBill
I agree with rockfordroo, weight does not have much affect on highway millage, once moving the major issue is wind resistance. Weight hurts city millage much more, accelerating uses more gas the heavier the vehicle (but I am guessing 85% of your miles are highway).
I have a 2006 255DS without modifications and I don't get over 10 mpg unless I drive off a cliff (cruise set at 65 I don't get much over 9mpg).
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
https://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 12-06-2016, 08:00 AM   #5
CAT-RN's Avatar
Very little change for 350 #. Cost quite a bit to change counter out. So that loss be much more.
Russell
CAT-RN is offline   Reply With Quote
Old 12-06-2016, 08:20 AM   #6
Dave Lyon's Avatar
Russell
They were probably expensive options at the time and could help with resale value when you're ready to sell.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 12-06-2016, 09:12 AM   #7
You're driving a motorhome with a huge V10 engine. Quit worrying about mileage. Never even calculate it again. Doing so is just sabotaging what should be fun times. Unless you just need something to be upset over...
Old 12-06-2016, 10:08 AM   #8
RedLdr1's Avatar
I get 8-9MPG with our GTS both fully loaded and lightly loaded. Three hundred and fifty pounds isn't going to make much, if any, measurable change in your MPG. As other have said you'll spend more money replacing the upgrades, down grading?, than you will save in gas...
I would visit a scale and check how much cargo carrying capacity (CCC) you have left after adding in the weight of the upgrades. That 350-400 pounds came right out of your original CCC rating.
2024 Sunseeker 2150SLEF on a 2025 Ford E-350 chassis with "Godzilla" 7.3L and 6 speed automatic transmission. "Trekker" Cap, Solar, Suburban IW-60 On-Demand Water Heater, All MaxxAir Fans, Progressive EMS-HW30C, Pacific Dually "Hub Caps".
TOAD: 2024 Ford Bronco Badlands, 2 Door, 2.7L EcoBoost, 10 Speed Automatic, 334A Luxury Package, Leather, Blue Ox and RVi Flat Tow Equipment.
RedLdr1 is offline   Reply With Quote
Old 12-06-2016, 10:18 AM   #9
It ain't an economy car....
SidecarFlip is offline   Reply With Quote
Old 12-06-2016, 01:30 PM   #10
Tom48's Avatar
Ditto
Tom48 is offline   Reply With Quote
Old 12-06-2016, 01:41 PM   #11
Originally Posted by RKanehl View Post
I JUST PURCHASED A 25.5 LEXINGTON WITH THE FORD V10. THE PREVIOUS OWNER ADDED GRANITE COUNTER TOPS AND HEAVY ROCK FLOORING. THIS ADDS AT LEAST 350-400 LBS. MY GAS MILEAGE AT 60MPG IS 9.3MPG. WOULD i GET BETTER MILEAGE IF I CHANGE THE COUNTER TOP AND FLOORING TO A LIGHT WEIGHT MATERIAL.
RICHARD KANEHL
2007 LEXINGTON CLASS C - 25.6
LEESBURG FL.
Leave all your passengers at home and it will equal out!
Seriously, folks add 350-400 pounds all the time by filling the fresh water tank or added gear. You will not notice the difference.
Also, to the OP... typing in ALL CAPS is considered SHOUTING on internet forums. You likely didn't know.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 12-06-2016, 01:49 PM   #12
wmtire's Avatar
No biggie. It happens a lot, and is fixed now..as many members may also not be aware of the following.
Posting standards: Forum members may use standard fonts available on the forum. The standard font size is 2. The use of bold, large or colored fonts should be used sparingly. Posts containing inappropriate formatting or content will be removed or modified at our discretion; e.g. all caps or excessive color. E-mail addresses and web addresses are not appropriate forum user names.
2011 Flagstaff 831 RLBSS
What if UFO's are just billionaires from other planets?
Old 12-06-2016, 01:52 PM   #13
mpg
I'm guessing your rig is a e450 chassis. Take everything out of it, drain the fresh water tank, take it for a ride and see how you like the ride.
markb422 is offline   Reply With Quote
Old 12-06-2016, 02:01 PM   #14
2003 Georgetown 325
NOPE.
reddiver is offline   Reply With Quote
Old 12-06-2016, 03:07 PM   #15
rvrobocop's Avatar
I hate to appear rude or insensitive, but as I am retired and still run two vehicles besides my MH I do understand your query. However, if I worried about MPG and/or the price of gas as I am rolling down the highway, it would be a long day. I have pondered this for most of my life since seeing it on a refrigerator magnet in 1967...."Today is the tomorrow you worried about yesterday".
rvrobocop is offline   Reply With Quote
Old 12-06-2016, 03:34 PM   #16
Any additional weight will reduce fuel mileage, but I highly doubt you will notice an additional 350lbs.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 12-07-2016, 07:18 PM   #17
I see maybe 1 mpg difference with our Sunseeker when towing a 4000 pound SUV or not towing. 350 pounds makes a difference but you would be hard pressed to detect it. Unless you need to lighten your motorhome to carry what you want, don't worry about it.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 12-07-2016, 07:55 PM   #18
FEIW, when I load my 1,000 pound Harley in the trailer the mileage doesn't seem to change at all.
BIRDS AREN’T REAL
gas, mileage
