If you had a Genesis Technologies GT 3.0 like our 2010 does it is no longer available except maybe on ebay. However there is a plug and play replacement available from Crutchfield and probably others. It is the iRV iRV66 and is supposed to be an upgrade. If you purchase the available wiring adaptor it will plug into the coach wiring harness that used to plug into your GT 3.0. It is expensive but maybe your insurance will help since it was destroyed by a leak.
Hope this helps.
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
