Old 01-14-2023, 05:56 PM   #1
Front TV Mount
My dad has a 2010 Lexington GTS. The HDMI on the front TV appears to have come loose and I am trying to figure out how to get the front TV off it's mount to plug back in. I am pretty technically and mechanically inclined, but I can't figure it out. I took the headliner off under it, but there is a metal plate so that didn't help. Any help would be greatly appreciated. TYIA.
Sdodom69 is offline   Reply With Quote
Old 01-14-2023, 06:26 PM   #2
Is it mounted solid on a wall? These are typical solid wall mounts and it just requires lifting up to disengage. It can require a bit of force because the vibrations from travelling on the road will cause the TV to settle into the mount all the way possible.
NavyLCDR is offline   Reply With Quote
Old 02-06-2023, 08:46 AM   #3
Which Lexington?
We also have a 2010 Lexington 300S GTS. There are several other models. The front TV in ours was mounted to a metal bracket that had 4 screws into metal angle - 2 at top and 2 at bottom. The bedroom TV is mounted on brackets like in previous post- also a bracket like that for outside mounting.
Hope this helps.
Danimal713 is offline   Reply With Quote
mount, tv mount
