Old 06-03-2020, 04:43 AM   #1
How much draw on batts while cooling fridge?
Lexington 283......2005......recently acquired
At storage site, I'm not able to plug in
In order to cool down fridge overnight, prior to a trip, how much draw is it on my batteries?
Thanks, I'm new
Jerry
Lexington 283 is offline   Reply With Quote
Old 06-03-2020, 04:56 AM   #2
bikendan's Avatar
RV fridge or residential fridge? On propane or not?
would help if you posted make and model number of fridge.
Equalizer WDH
Old 06-03-2020, 05:17 AM   #3
Dometic RV Fridge (Original in MH)
Yes, run on propane in order to cool fridge prior to trip
Model number unknown
Will running of this fridge & freezer on propane draw down my coach batts?
Thank you
Old 06-03-2020, 06:41 AM   #4
Kanadian Kamper
kenandterry's Avatar
Problem is compounded by not knowing how long your Lexington has been sitting (unplugged) since the last time your batteries got a full charge.
Youíre asking how much your fridge will draw in order to cool prior to a trip but your starting voltage will be?...........
If this is going to be a regular procedure, you may have to invest in some solar power to help keep your batteries at their prime.
Ken and Terry
2018 Sunseeker 2430S
and only sometimes pushed by our 2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 06-03-2020, 06:50 AM   #5
Chuck_S's Avatar
LP refrigerator requires very little 12vDC power (mine draws a measured 120 milliamps) and if the power fails they usually keep running on the last mode. If the frig starts it should keep running, it's just a little flame.
You'll find out how it worked in the morning.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-03-2020, 06:53 AM   #6
Brake is on left
The Evil Twin's Avatar
If your batteries are in good to excellent condition then 24 hours will be no issue at all on a propane fridge. We regularly let the fridge go 24 hours before we leave and often when we get home. The meter still shows a charge in the good range when we roll. The key is having a good, charged battery at the beginning.
The Evil Twin is online now   Reply With Quote
Old 06-03-2020, 10:45 AM   #7
If all you're running is the propane fridge the battery(s) should last a lot more than 24 hours. The refrigerator control board is one of the least power hungry items in an RV.
It's the propane that does the work so just make sure the tank(s) have plenty.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-03-2020, 11:01 AM   #8
But while you are sort of correct.... you forgot to tell the person that while in this condition he is also powering the carbon monoxide and smoke detectors and due to this the batteries may last 3-5 depending on condition and starting charge. If you isolated it to the PC board in the fridge only, it may last a couple weeks. I know when I bought my camper last year I was shocked to discover that the single battery installed was not good to go a long weekend with no power. As a new camper buyer... I just assumed that these things were set up for camping over a weekend and living entirely off of the battery and water tank. Then reality hit.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is online now   Reply With Quote
Old 06-03-2020, 11:13 AM   #9
Semperfi24's Avatar
The fridge would probably not draw down the batteries, making the assumption they are good batteries and fully charged. The problem you will have will be all of the "other" things in the RV that also run on the 12V side.
If I were you, my solution would be to get a portable solar kit. Doesnt have to be large. Just one panel to trickle charge the battery. Wire it directly to the battery. That is what we do in our storage lot. One panel that is 12"X30", wired to a controller, then to the battery. We never have to worry about dead batteries, and it is plenty for us to turn the system on ahead of departure without concern. When we are ready to leave, unhook the panel and store it.
_________________________
2019 Ford F250 Lariat 6.7 Powerstroke
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 06-03-2020, 11:23 AM   #10
Brake is on left
Of course. Though, my reply was to the OPs question about "overnight" use.
Old 06-03-2020, 11:34 AM   #11
NMWildcat's Avatar
Now I know you have been on the forum long enough to realize you have to very precise in your wording to avoid being nitpicked
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-03-2020, 12:20 PM   #12
Agreed, the LPG detector will also be running and perhaps the smoke detectors if wired in series and in several rooms but most RV smoke detectors I've encountered use individual batteries. CO detectors are more often than not integrated into the LPG detector on units built in recent years..
That said, I have actually measured all the power drawn by refrig, LPG detector and even the stereo "Memory" current. All consume only milliamps of current and my battery monitor shows only 4 watts of current draw, max.
That works out to less than 8 amp hours over a 24 hour period.
In short, even a small, undercharged, or aged battery, should easily run the refrigerator for more than 24 hours.
2004 Nissan Titan
Old 06-03-2020, 12:34 PM   #13
Chuck_S's Avatar
Measured amperage draw (my Roo).
LP detector and radio memory: 150 milliamps (These are hard wired to the battery.)
LP refrigerator: 120 milliamps
Total: 270 milliamps (0.27 amps).
As long as the LP detector isn't screaming from low voltage this should work.
-- Chuck
Old 06-03-2020, 01:06 PM   #14
Thumbs up
Thanks, I'm new
Jerry
We sort of had a rule of thumb with our rig. Running the typical 12 volt items we could go for most of three days before we had to recharge the house batteries. As I understand the most current is the draw by two solenoids one for the actual gas flow and the other for safety if and when the pilot light goes out allowing the gas to continue to flow. In order to accomplish this we made sure that we had only led lighting for their low current draw. We were equipped with two 6 volt batteries.
jjtotten is offline   Reply With Quote
Old 06-03-2020, 02:03 PM   #15
If you can plug it in do that overnight and run the fridge on electric. When you unplug it should automaticly switch to propane. Battery wise you can go weeks n just propane it is the other draws that get your battery down.
slgjeg435 is offline   Reply With Quote
Old 06-03-2020, 02:16 PM   #16
bikendan's Avatar
The OP stated this in the first post:
"At storage site, I'm not able to plug in"
Equalizer WDH
Old 06-03-2020, 02:49 PM   #17
NXR
NXR's Avatar
It really depends on the fridge model. Norcold four-door units (at least) have a heater element for the door. That can draw a lot of current if the fridge thinks those heaters need to run. Some people have put tape across the door contacts to save battery power.
A friend with a Norcold 18 cubic foot four-door fridge measured 3 amps of current flow without the door heaters. He barely could run the fridge overnight on batteries.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 06-03-2020, 02:59 PM   #18
Ray
Residential type with compressor or an RV type using LPG when not on shore power?
HUGE difference.
2004 Nissan Titan
Old 06-03-2020, 03:02 PM   #19
As you have seen, there is no 'standard' answer.
Every make/model refrigerator draws current from the battery in different amounts.
The refrigerator control doesn't use a lot of battery but the door heaters and fans can use more current. (mine has two door heaters and 4 fans!)
And then on a 2005 there is the question of what condition the battery is in, how much charge capacity it has when firing up the refrigerator and what other parasitic draws are on the battery as well.
Without an amperage test and knowing the battery capacity we are all just guessing.
If you are not able to figure those numbers in advance, just try it and see.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 06-03-2020, 07:51 PM   #20
NCBBA11043's Avatar
On a side note . . .
If you are at a commercial storage site, they may prohibit you from running any appliances on LP. It's a liability thing...
2015 Silverado 3500HD CC Long Bed Diesel
2016 Silverback 33IK
NCBBA11043 is offline   Reply With Quote
cooling, fridge
