Don't buy the whole converter
bb
Originally Posted by nvs4602
When you open the door to look at breakers and fuses there should be a service plate with the model #. You won't need to replace the whole thing, just the power supply part. Which on my wfco 8955 was a 15min job. If you think you might go lifepo4 batteries in the future get the one with the selector switch for battery type.
Don't buy the whole converter assembly. You just need the main board. The part number is WF8955 MBA (Main Board Assembly). It really is a 15 minute job.
The b that supports an upgrade to Lithium batteries if you think you might upgrade. (It comes with a replacement fuse board. I wouldn't spend my time installing the new fuse board.)
Larry
