Old 03-05-2016, 06:48 PM   #1
Pre Wiring
Hi all,
We have (New to us) a 2007 Lexington GTS 255 DS. It does not have a bedroom TV. I was wondering if there is any pre wiring to the opening were the bedroom TV would go? How about for a satellite dish on the roof? Thank you, enjoy.
mrv8outboard is offline   Reply With Quote
Old 03-07-2016, 11:43 AM   #2
Send a message via AIM to NoviBill
I have a 2006 (New to me last year - by the way Welcome!) and it has a TV antenna with amplifier in the front and in the center wardrobe in the bedroom is a 12volt outlet, a 110 outlet and a coax from the antenna. All of the connections are hidden in this photo, but are in the opening above the draws on the left side.
Lexington 255DS - Bedroom wardrobe by cdrdwd, on Flickr
I will get out to the MH this weekend if you need a better photo (monthly start and check).
-Bill
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
https://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 03-07-2016, 01:48 PM   #3
Awesome thank you.
Old 03-07-2016, 02:00 PM   #4
So mrv8outboard, where are your from? How do you like the Lexington so far? Is this your first RV?
Old 03-07-2016, 09:26 PM   #5
I am from Cape Cod. The Lexington is being picked up tomorrow. It is a good friends new purchase. We have our third RV and that is a Tiffin.
Old 03-07-2016, 09:55 PM   #6
We are "pre retirement" and the 255DS works great for us, small enough for us to drive anywhere, big enough that we are not tripping on each other. Having a true bedroom is a great upgrade from our old hybrid.
You can find lots of info here, one key thing I found out was that the tank fill hose is often loose (someone posted it). I checked mine and it could have fallen off... Check under the bed. Also add some padding where it comes through the cut-outs in the frame, others have said they will rub and leak over time.
Good luck!
Old 03-08-2016, 08:28 AM   #7
It is being picked up today so I will check it out when it gets here. Thank you.
wiring
