currently I am setting up a piece of 4 inch sewer pipe (white) with the end cap cemented on and on the other end the pipe there is a clean out adaptor and fitting. I can then use the Dump station wrench to seal the hose internally. no pad lock needed past that point.
Camping World sells the wrench under Catalog Item # 70031.
This tool works great when travelling and someone else has cross threaded or over tightened the sewer cap on the ground as well.
I cut my pipe 6'6" long - enough for 2 hoses to be inside if needed.
I'm not going to paint it because once the paints starts to flake and chip off it will be one more task I will come to hate when I could be doing something more important like spending time with my granddaughter.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
