Old 10-16-2020, 05:31 PM   #1
Slide outs, generator and steps don't work
2004 255 GTS, last trip I took I noticed the slide-outs and steps were moving slower than usual. Then stopped working, worked one more time and now they don't work at all. No 12VDC to the steps or slide-out motors. (I haven't checked the voltage to the generator, but I'm sure it's not there, either.) Everything else works fine; vent fans, lights, etc. Inside the battery compartment I checked connections on two solid-state relays, one mounted on either side of two large, cylinder-shaped components. On the left side of all components I get 11VDC, on the right side I get 13.8VDC (shore power connected). Since this was a slow-death sort of problem I'm pretty sure it's not a SSR. (All fuses and breakers on the power supply under the bed are OK.) Any thoughts?
Rednekz is offline   Reply With Quote
Old 10-16-2020, 09:25 PM   #2
OK, it seems I'm referring to the "BIRD". (Searching helps, doesn't it?) I still ASSume my problem is a common relay/connection for the heavier motors.
Old 10-18-2020, 11:19 PM   #3
HerveVR's Avatar
It look like your problem is due to weak house batteries.
Disconnect them to check the voltage, if low, charge them with an outside battery charger.
Slides ans steps are, usually, protected by fuses or breakers that are near the batteries box.
Hope this helps !
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
Old 10-19-2020, 04:58 AM   #4
That seems to be the problem. Funny thing is, about five minutes after I started charging them, the charging solenoid engaged and started charging them from the onboard charger. The batteries ran down again, so I turned the charger back on and the same thing happened. Been working ever since. Think the BIRD is on it's way out.
Old 10-20-2020, 12:04 AM   #5
HerveVR's Avatar
If your BIRD is on his way out, he might go South. Most of them are flying that way at fall.
generator, slide, slide out, steps
