Old 05-16-2022, 08:59 AM   #1
sas7001's Avatar
Water Heater Toggle Switch
Trying to figure out the purpose for the on/off toggle attached to the water heater accessed from outside, and the on/off 'Water Heater' toggle on the inside control panel. Someone told me the inside controls the propane and the outside controls the electric. 2006 Lexington 283.
Steve & Cindy
2006 Lexington 283GTS w/Ford 450 chassis
Since Fall 2021
sas7001 is offline   Reply With Quote
Old 05-16-2022, 09:04 AM   #2
PopFla's Avatar
Exclamation
Someone was absolutely correct. Why Suburban water heaters are set up that way escapes logic. Many folks leave that switch turned on and use the circuit breaker inside the coach to activate/deactivate the electric heating element.
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
CAMPING (n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
PopFla is offline   Reply With Quote
Old 05-16-2022, 10:36 AM   #3
I didn't know there was a switch on the outside. I've always controlled the AC with the circuit breaker and the LP with the switch on the control panel.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is online now   Reply With Quote
Old 05-16-2022, 10:38 AM   #4
wmtire's Avatar
Sounds like you have the Suburban SWDE water heater. This thread link below will fully explain the switches and operation of this:
https://www.forestriverforums.com/fo...tml#post327988
2011 Flagstaff 831 RLBSS
Old 05-16-2022, 10:49 AM   #5
Mr. Dan's Avatar
Here’s MY logic for wanting it that way. I’m in my 5er 90-115 nights per year and always in sites with electricity. When I arrive at a campsite, attach my water hose from the campground water faucet to my trailer, I’m standing 4’ from my water heater and its outside switch. I turn that switch ON and leave it on until I leave - usually ~ 2weeks later. When I break camp and unhook my water hose, I turn that outside switch OFF since I’m standing next to it.
Old 05-16-2022, 11:06 AM   #6
PopFla's Avatar
Exclamation
In my case, the water heater is on the opposite side of the coach. Like many other things with these rigs, what works well with one model may be inconvenient with a different model.
Old 05-16-2022, 10:25 PM   #7
BobHanke's Avatar
FYI: The outside switch on Suburban water heaters is a "rocker switch".
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
Old 05-17-2022, 10:08 AM   #8
Mr. Dan's Avatar
So your “escapes logic” only applies to your opposite side configuration?
Old 05-18-2022, 06:15 AM   #9
I turn my electric "rocker" switch on at the begin of season and off at the end. Is there a reason switch it off every time I move? I don't drain it until end of season.
2019 Heritage Glen 282RK
2014 F-150 Screw 4x4 3.5EB
lewisra is offline   Reply With Quote
Old 05-18-2022, 06:55 AM   #10
KyDan's Avatar
Not really. I left mine on for some time and it stuck on. This is common with that switch. Some folks change out the stuck switch and some (myself included) just use the circuit breaker to turn it off. As long as you don't drain the tank I see no reason to turn it off when moving.
My 2¢ (others may say "oh you'll wear out your circuit breaker" but I've never had a problem and circuit breakers are cheap and easy to replace but I've never had to do it!)
Happy Trails!
Peace!
Dan & Rita D
Old 05-18-2022, 07:58 AM   #11
It's super-inconvenient for us too. Our city water connection is located on the back of the coach. Even if we're filling the water tank, which is right next to the water heater, one of us needs to go inside the coach to turn on the water pump to fill the water heater first so we don't burn up the element. Granted, we don't drain the water heater in between camping trips, but better safe than sorry. Also, if you turn on both the electric element and the gas and forget, the water gets ridiculously hot. Experience is a great teacher in that case.
2022 Wildwood X-Lite 273QBXL
2019 Nissan Titan XD Diesel
K_M_H is offline   Reply With Quote
Old 05-18-2022, 08:07 AM   #12
wmtire's Avatar
This shouldn't happen, it sounds like you may have a faulty/loose thermostat on either the propane or electric element mode of heating (there are two thermostat assemblies on a Suburban water heater)
You may want to remove the plastic/rubber cover (which has reset printed on it) over the thermostat assemblies, then make sure both are snug against the tank wall (see the middle bolt on both assemblies?). If one is loose and is not making good contact with the tank wall (sometimes rust forms behind it too), then it may heat up higher than it should before opening the t'stat and cutting power to the heating source.
The left thermostat assembly goes to the electric heating element mode, and the right goes to the propane mode. These two separate/independent thermostat assemblies is what allows the electric heating element and propane burner modes of heating to operate totally independent of one another....and why you can have one or both turned on at the same time. BOTH thermostats are "supposed" to open up (cut off power) when they sense the tank wall get to around 130 degrees. If one mode of heating is perhaps getting as you say"ridiculously hot"...then it is failing or not making good contact with the tank wall.
Old 05-18-2022, 08:16 AM   #13
Mr. Dan's Avatar
As we see above, we don’t all have the exact same situation. When I’m home between trips (5 to 15 days), my trailer is plugged in to a 50 amp outlet. I don’t need/want any degree of hot water - don’t need/want the water heater using electricity. At my age, I’d rather flip that outside rocker switch than to get on my knees to throw the breaker barely above floor level.
Old 05-18-2022, 11:37 AM   #14
-- Snip! --
Thanks for that. For some reason the whole "thermostat could be faulty" thing had completely slipped my mind. Probably has something to do with working from home, trying to manage a toddler and a Catahoula puppy at the same time. I'm really glad it didn't overheat while I was at the site.
Old 05-18-2022, 05:40 PM   #15
In my 30 amp Forester there are only a few AC power items. AC, microwave and water heater are the big amp hogs. Assuming the fridge is on AC and the converter is doing its thing I can easily run two of the three large draw items simultaneously. Running all three at once usually results in a tripped main breaker. So, in order to not have to turn stuff on/off all the time I leave the electric heat off except when it’s shower time.
FWIW, the water electric is controlled with a inside controller (one control panel touch screen).
BIRDS AREN’T REAL
Old 05-18-2022, 06:08 PM   #16
Had the outside rocker switch but that switch is a weak point and fails a lot . So when mine failed i bypassed in and installed lighted switch inside . Now i can see when it's no or off and turn it on or off anytime with out going outside and removing water heater cover . some surburbans have have an electric switch inside along with the one outside . right next to the propane switch so every unit is different and even same models from one year to the next can be set up completely different.
MR.M is offline   Reply With Quote
heater, switch, water, water heater
