11-15-2020, 11:42 PM
What's that bracket for?
I was performing a wash/wax clean-up job today on our 283ts Lex. The exhaust pipe exits aft of the entry door and while I was cleaning the chrome tip on the pipe I was trying to figure out the use for the funny bracket attached to the exhaust heat shield.
I get that the heat shield protects the external storage compartment directly on top of the exhaust pipe but the attached bracket is a mystery.
Does anyone have a clue as to what it's for? See the attached image.
Thanks.
David Wood
2008 Lexington 283TS GTS
11-16-2020, 09:56 AM
Was it like that from the factory?
Retired Navy
2016 Flagstaff 26 FKWS
11-16-2020, 10:36 AM
I'm the third owner of the coach so I can't be 100% sure but it seems like it's part of the original heat shield install.
David Wood
11-16-2020, 10:48 AM
Kanadian Kamper
One of the previous owners is having a giggle with the next owner(s).
Never seen an attachment like this on any other Class C units.
Ken and Terry
2018 Sunseeker 2430S
and might rarely get pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
11-16-2020, 02:23 PM
Looks to be a hardware store bracket. I'll bet if you go to your nearest ACE you will find it although it appears to have been cut off on the end that is bolted to the plate.
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
11-17-2020, 05:32 PM
Possibly to protect the basement door from hitting the hot exhaust pipe?
11-18-2020, 07:35 PM
I wish that were the case, but it doesn't extend out far enough to keep the door from hitting the pipe.
And the mystery continues......
David Wood
11-18-2020, 08:58 PM
Thanks.
Maybe somebody used an XR-2200 on your motorhome.
Seriously, I'm wondering if a previous owner may have had some kind of personal plate or something and had a mounting bracket there.
 2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
11-18-2020, 09:08 PM
It’s the bracket for the light connection. The previous owner was absolutely convinced the round pipe thingy was the trailer hitch receiver. He eventually learned otherwise.
11-18-2020, 09:38 PM
ROFLMAO
David Wood
11-18-2020, 09:39 PM
Maybe a mounting bracket for an "exhaust" deflector?
David Wood
11-18-2020, 09:54 PM
What's that for?
David_Wood
“Audio/Video Design Engineer, Mechanical Engineering, Astrophysics”
Dude... what do you do for a living? You got some splainin’ to do!
11-19-2020, 05:32 PM
Before it was accidentally bent 90 degrees, it was used as a boot scraper to scrape off the mud that collects in the arch in front of the heels of your cowboy boots.
Larry
11-19-2020, 10:25 PM
Have the same on our 2012 Lexington 265DS, it is a kind of «heatsink» protecting the above side panel.
When we had the muffler and tailpipe replaced last year, the exhaust repairman put a new one one the new pipe.
11-19-2020, 11:56 PM
David_Wood
That's a long story - Cliff notes version:
I just recently retired after 40 years of systems engineering/design and integration in both commercial audio/video for the military and wide-area wireless data communications (mostly cellular data systems)
In recent years I've been working with NASA, Caltech, and several universities in studying Exo-Planets orbiting other stars. I also mess around in astrophotography.
Fun stuff...
David Wood
11-20-2020, 01:07 AM
When we had the muffler and tailpipe replaced last year, the exhaust repairman put a new one on the new pipe.
A heatsink?
OK -- I'm a bit confused as to how the bracket contributes to the performance of the heat shield. Normally heatsinks have significantly more surface area than the devices they are "sinking" the heat from.
David Wood
11-20-2020, 01:44 AM
Sorry, I missed the bracket. Only saw the plate, acting as a heatshield rather than a heatsink.
Seems like a add-on, no clue.
11-20-2020, 07:11 AM
Bracket on taipipe
Excuse me for being brain dead for a proper name. I think it is to hold the exhaust pipe that goes above the roof of the camper to keep fumes from entering rv. Someone in a camper next door to some one running a generator without the pipe died across the street at Indianapolis Motor Speedway just a few years ago. So if you were boondocking without a generator using engine to boost batteries up you wood want one of these pipes. I think there called Gen-Turi and it has been adapted for the regular exhaust pipe.
11-20-2020, 07:26 AM
Pipe bracket
After looking at some you tubes it looks like the one pictured might have been installed at the shade tree garage.
11-20-2020, 07:35 AM
I don’t know about that. If you look at the high-resolution version of the picture, it looks like this bracket is designed to be where it is, except it is placed about an inch or so too far from the rear. The notch in the plate looks like it is there to avoid conflict with the nut in the larger plate. It looks like they shifted it and secured it to the large plate with only two bolts instead of four as there are four holes drilled into the smaller plate and only two of them are being used.
Here’s a link to the higher-resolution picture:
https://www.forestriverforums.com/fo...9&d=1605501540
Bruce
