06-04-2020, 04:56 AM
Towing questions
Hello need help.
I have a 2016 Lincoln Navigator 4x4 with the Ecco boost v6. Just purchased a 2020 grey wolf 23dbh. Weights 5380lbs. Think I can tow this? Thanks
06-04-2020, 05:34 AM
What's the payload and towing capacity of your TV and hitch weight of your trailer?
06-04-2020, 05:39 AM
Originally Posted by pro417
Hello need help.
Yes please post payload capacity number, from driver's door yellow sticker. It's the Tires and Loading sticker and says "Occupants and cargo should not exceed xxxxlbs".
And please don't use fictional brochure/website dry weight numbers. Those numbers are based on a stripped-down version of the trailer.
That trailer is over 29ft long. Not sure if I'd want to tow that with a 1/2 ton SUV with soft suspension.
06-04-2020, 05:50 AM
Payload is 1620lbs. Hitch weight of trailer is 630lbs.
06-04-2020, 06:23 AM
SPECIFICATIONS
Hitch Weight: 621 lb.
GVWR: 7621 lb.
UVW 5380 lb.
CCC 2241 lb.
Exterior Length: 29' 1"
Exterior Height: 10' 6"
Exterior Width: 96"
Fresh Water: 44.00 gal.
Gray Water: 38.00 gal.
Black Water: 28.00 gal.
06-04-2020, 07:23 AM
Brake is on left
You will likely be pushing the limits of the Navi. That is an empty tongue weight posted. Loaded, your tongue weight will be close to 1000. Then add a couple people (and a dog?) and anything you toss in the cargo area.
06-04-2020, 07:50 AM
Would Weight distribution bars help?
06-04-2020, 08:22 AM
WDH is required, you should get one with integrated sway control, Blue Ox, Equilizer 4pt etc.
How much weight, including people and cargo will be in the navigator? from the numbers above you have about 600lbs available.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
06-04-2020, 09:02 AM
With the short wheelbase Navi, sway might be an issue .
Like this Expedition (same as a Navigator) towing a similar size TT.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
06-04-2020, 10:46 AM
Hello need help.
I would tow it with that. However, take the time to learn how to set up your hitch yourself and how to load a trailer to prevent sway.
2016 26RR and a 2018 OR371MBH
06-04-2020, 10:54 AM
Pfffftttt . . . that'll buff out . . .
It is amazing though, once that fishtailing starts, it rarely ends well!
Be Safe!
2015 Berkshire 34QS
06-04-2020, 12:14 PM
Grammar Pedant
Originally Posted by llr
WDH is required, you should get one with integrated sway control, Blue Ox, Equilizer 4pt etc. [...]
Definitely! When I moved up from a 1/2 ton to a 1 ton, I don't actually need to redistribute any weight. So, from a purely weight distribution perspective, I don't need a WDH. With that said, I'd never tow without one.
The sway control (anti-sway) is nearly magical. I have an Equil-I-zer, but I am sure that any good brand will be equivalent. But, my trailer always feels fused to the back of my rig. Maneuvers, massive winds of CO and the midwest, passing and being passed by big rigs, twisty mountain roads, and so on all have almost no effect on how my trailer tracks ... this is with the 1/2 ton towing and with the 1 ton towing.
It's no fun dropping another $500-$700 on a hitch after already feeling like you spent a ton of money on the RV. But, I highly recommend a WDH for any conventional tow trailer, outside of maybe pop-ups.
Former RV: 2018 Rockwood Mini Lite 2504S
06-04-2020, 12:54 PM
Brake is on left
WDH does not change how much payload your vehicle can carry. It just distributes some of that load to the front wheels. As someone posted above, it is required for your vehicle anyway.
Some folks will say send it, others will say you are crazy for overloading a vehicle by a couple hundred pounds. IMHO, the deciding factor is weather you overload your axle ratings.
06-04-2020, 01:06 PM
Predator59
Yes you can...will it be safe? No.
06-04-2020, 05:51 PM
From the numbers you posted seems fine to me. I would expect your tongue weight to be about 800lbs with a loaded trailer.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
06-04-2020, 07:31 PM
Originally Posted by corn18
SPECIFICATIONS
GVWR: 7621 lb.
UVW 5380 lb.
CCC 2241 lb.
Exterior Width: 96"
That hitch weight will be closer to 1000 lbs once loaded
06-04-2020, 07:40 PM
Here is the math for you to make a decision.
HW = hitch weight of TT (12% of loaded trailer weight).
100= weight of WDH hitch
C= Cargo weight in tow vehicle
PW= weight of passengers
the math
1620- (HW+100+C+PW) should be greater than 0
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
