Old 01-05-2024, 06:51 AM   #801
MCTroy
Originally Posted by SailorSam20500 View Post
Anyone take this as a challenge??
Yes!
MCTroy is offline   Reply With Quote
Old 01-05-2024, 11:30 AM   #802
SailorSam20500's Avatar
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 01-05-2024, 01:12 PM   #803
We have this exact unit at our campground
That's an MPH Industries Speed Trailer. We have one at our campground. "I've been appointed as the unofficial maintainer of the unit, although the biggest problem is getting people to charge the batteries when needed.
The campground is located in the Tidewater area of Virginia. The sandy soil there is so fine it's like dust. The speed limit for the entire campground is 5 mph. Even golf carts can throw up a cloud of dust if they go any faster. RVs on the busiest roads always have a coating, inside and out.
The unit shows speeds that low, but won't alert at speeds lower than 10 mph. The owner keeps asking if I can hack the internal software to get alerts above 5 mph. If I had a little more documentation than the user manual, I might try it.
Larry
Larry-NC is offline   Reply With Quote
Old 01-05-2024, 03:25 PM   #804
If it were me I'd be pulling it apart to see what it has for brains inside. I've never looked into one of these, but it's likely it has a microcontroller that could be reprogrammed. Lots of reverse engineering though of the radar, display, and power systems on it. Not often you can reliably download and easily reverse engineer the code on a commercial system like that.
If I were up for a project I'd design a new control board for it and reuse the existing chassis, power, radar, and display. But that's just me.
2021 Forest River Wildwood 171RBXL
Towed by 2018 Toyota Tundra TRD SR5
reidfo is offline   Reply With Quote
Old 01-05-2024, 07:06 PM   #805
Harder than it looks
I spent a good deal of my career (19 years before retirement, 10 since) reverse-engineering competitor electronics. I'm no stranger to it.
The mainboard is the size of that sign. It's huge and has the RF stuff and a huge array LEDs for the display and a couple of other functions. And all of it is on the front side. It's gotta be three feet square.
The processor is likely to be identifiable--I don't think they would use a custom chip--but I'd have to trace all the inputs and outputs to see what they control. There's a 16-value rotary digital switch (five lines) that sets the alarm level, starting at 10 mph and going up in 5 mph increments. I'd have to find and change the code that reads those inputs and change the base or scale factor. This means working and patching in raw assembly.
Then desolder the instruction store (on the processor chip or separate) and reprogramming it (if erasable) or finding a part equivalent to a 20-year-old part and programming that--if I could find a programmer device for a part that old.
Not planning to take this on. Too many things could go wrong and render the device permanently disfunctional.
Larry
Old 01-06-2024, 07:45 PM   #806
What? No solar panels??
The one our local city parks in front of our house when people complain about neighborhood speed has a couple small panels mounted flat over dusplay.
TitanMike is offline   Reply With Quote
Old 01-06-2024, 07:53 PM   #807
Excellent idea. I'm going forward with it.
Any idea how much capacity would be needed? And controller type? I can't remember exactly what the current draw was, but I think it was 4 amps. That's around 100 AH in a day.
Larry
Old 01-06-2024, 10:01 PM   #808
If the "nameplate rating" is 4 amps that works out to ~50 watts to run the unit (12.5 v nominal).
I'm a fan of MPPT controllers but that pretty much dictates using two or more panels in series so the benefit of higher input voltage can translate to earlier start and later ceasing of charging occurs. Get to use more of the "solar power day".
I'd consider something like three Renogy compact style 50W panels running $46 each, an inexpensive 10 Amp MPPT solar controller (doesn't need bluetooth, etc so can be as little as $15) and then it's just a matter of some pre-punched angle iron to fabricate a mount. 50 watt panels are around 23" X 20" X 1-1/8". Mount "end to end" and wire in series. Mount the inexpensive solar controller inside so no need to pay extra $$$ for weatherproofing.
The 150 watts of "available" solar power should be more than able both keep up with running the unit during daytime as well as provide charging of the batteries. For even more "improvement" dump the Lead Acid batteries and replace with a single 100 ah LiFePo4 battery. Charging is almost 100% efficient compared to the lead acid batteries that are only 75%-85% efficient and that only allows for the I^2R losses due to battery impedence. And then add other factors like temp, as well as the condition of the battery (whether or not it will take a full charge due to age (sulfation).
150w total solar input to an MPPT controller should be able to provide ~12 amps of charging power (peak) and actual PV input current will only be ~4 amp so a small controller is more than adequate. It just needs to be able to handle an input voltate that is 3X the
Voc rating of panel (Renogy 50W=22.3Voc) (note: Vmp for the renogy panels is only 18.6v but I would size the converter for 3x 22.3 volts as that's the max the controller would see in an open circuit condition, just for safety.
Footnote:
Actual power consumed will most likely be far less while in "monitoring" mode and only use max power when it needs to power up the "Alert/Warning" mode. Depending on how many vehicles pass, the it will more likely be more "charge" than "discharge".
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
Old 01-19-2024, 12:32 PM   #809
Al
Old 02-02-2024, 03:25 PM   #810
Al
Old 02-06-2024, 01:50 PM   #811
Al
Old 02-06-2024, 09:16 PM   #812
Did WHAT!! Meeeh??
(I'll never admit that!! )
2012 Rockwood A122, 2017 2018 Kia Sorento 3.3 V6 AWD,
(2012 Subaru Forester with MT & the 2017 Sorento have gone to TV heaven))
Cheers and greetings from a Toronto Canuck
Brandoni is offline   Reply With Quote
Old 02-07-2024, 05:02 PM   #813
Truth, how much justice can you afford!
_______________
2020 Plat F350 diesel DRW
2021 Riverstone Legacy 37mre
filthy-Beast is offline   Reply With Quote
Old 02-08-2024, 07:57 AM   #814
Defender of America
Nick Danger's Avatar
I'm going to need someone to define "justice" for me. I've become incredible confused about that word in recent years.
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
Nick Danger is offline   Reply With Quote
Old 02-08-2024, 10:45 AM   #815
There is a difference between moral / ideal Justice and the way the real world works.
_______________
Old 02-11-2024, 08:39 AM   #816
DogMan635's Avatar
Originally Posted by elind View Post
At our 55+ resort.
If they would only STOP the Drinking the probably, would not be slow.
2021-MB Coachmen, Galleria, Li3, named "Greta"[
May the best RV Road Trip adventures be your own.
DogMan635 is offline   Reply With Quote
Old 02-23-2024, 09:52 AM   #817
Defender of America
Retired USAF
Centerline TS WDH
Old 02-23-2024, 10:35 AM   #818
yukongold's Avatar
What is even more disturbing is that this guy is now a judge.
https://taskandpurpose.com/culture/l...hie-judge-win/
2007 Sierra 2500HD Duramax | ECSB
2012 Rockwood Minilite 2104 - Purchased 08/2012 - Sold 07/2022
2022 SOB 29' 5th wheel - purchased 09/2022; 400w solar on roof; 150w suitcase kit; 206ah LiFePO4; 2k inverter; boondock ready
yukongold is offline   Reply With Quote
Old 04-04-2024, 11:04 AM   #819
Sign of the times...
Al
Old 04-05-2024, 06:10 AM   #820
Defender of America
God Bless America!
Retired USAF
Centerline TS WDH
