Morning, I found my slide leaks were caused by the seal from the awning above the slide. Been told it is is a common problem and the seal is standard can order off of internet. Looks easy to replace, I just need to get to warmer place to tear off and replace. Have to admit I Gerry rigged it with some Gorilla Tape for now and it held up through 5 inches of rain. As far as the side seals they are a standard size, but can be a pain to replace. I spray mine down with conditioner a couple times a season and it helps.
Hope this helped.
Good Luck.
2004 Tsunami 4104 QS
2008 JKU
Prepping for full time.
