Old 06-15-2021, 10:06 AM   #1
TV Replacement
Hello I recently purchased a 2005 Tsunami I am looking to replace the electronics. I need help removing the old TV in the front. Can anyone help me figure out how? I can't find any of the hardware screws holding it in place
Thank you all in advance
cadetgusv is offline   Reply With Quote
Old 06-19-2021, 10:09 PM   #2
Kind of a pain
I had to disassemble both cabinets internal shelving, long arms and a second set of hands…
Good luck…
Pkrbkr4fr is offline   Reply With Quote
Old 06-20-2021, 07:18 PM   #3
Good luck…
This is what I have come to conclude thank you for confirming.
I was thinking about going directly through the TV itself to access the bars it is bolted to. do you think this would be a better option taking everything apart?
It's a very early model flat screen my plan pending your opinion is to break through it then clean up the mess once I can access what its bolted to through the TV itself.
What yah think?
Old 06-20-2021, 07:30 PM   #4
One concern I have with going through the tv is not knowing what I will find.
Do the cabinets have to come down in order to remove the TV ?
Old 06-20-2021, 08:47 PM   #5
TV change.
It was pretty easy removing all the shelves and back panels. The right hand side had the radio amp and switch so it was not easy to access that side of the TV. But from the drivers side I was able to get to all the screws both to remove and install. I have a 40 inch TV little bigger then the hole which is nice but I had to offset the drivers cabinet door so it would open and close…
replacement
