Originally Posted by Karter
Dave, did you replace the monitor and the camera as well? It seems to be a bad connection. Does the wiring run under the roofing material, did you have to replace that too? Is there any trouble shooting tips you can give me? Thanks for any and all advice!
I only replaced the camera, not the monitor.
I only replaced a little wiring just where the camera is mounted and the wiring enters the roof in the back.
I don't know where the wiring goes from the top rear of the motorhome. RV construction techniques are geared toward allowing the manufacturer to build the thing as quickly and cheaply as possible. One thing that's often sacrificed is subsequent access for service - everything is stashed away behind walls and floors and ceilings, with no clear way to find anything unless you already know where to look.
I posted the 24R wiring diagrams a year or two ago. Here's a link to that thread:
http://www.forestriverforums.com/for...ms-123195.html
I don't know if those will help at all - I took a quick look but didn't find any mention of the rear view camera / monitor - they may be there, but I didn't find them.
Dave
