I would try getting an obd2 scanner that is compatible with your vehicle. Read out and record the fault codes. Then tell the scanner to delete them. This MAY get you out of Limp mode and allow you to drive the vehicle to a dealer (back to the guy who “fixed” it?).
Disconnecting the chassis battery (located inconveniently under the driver side floor) and waiting a while MAY also reset the codes, but you won’t have a record of them.
Note, I say these techniques MAY help. They also may not…
Good luck-
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
