10-15-2010, 07:29 AM
brania
help with furnace draining
Hello group,
My solera is in the driveway and I am investigating the procedure to drain all water. I can't find the freah water drain plug ( although I'm sure the dealer did show it to me ) and I can't seem to loosen the anode plug at the base of the furnace in order to drain it. Is there a special tool for this purpose. I just about broke my wrist trying to loosen it with an adjustable wrench, Is it just in there very snugly or is there a special tool>thanks for any suggestions.
Andy
10-15-2010, 07:34 AM
Furnace? Your furnace has water in it?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
10-15-2010, 07:58 AM
If you are referring to the anode rod on the water heater, it usually takes an 1 1/6th inch socket and a breaker bar to remove that. I can see why an adjustable wrench woudn't work....sometimes those puppies are in there tight.
10-15-2010, 08:54 AM
I used an 1 1/6" socket w/ an extension on a ratchet. How old is your trailer?
I'd stay away from the adj' wrenches as you're liable to mess up the flats on the head of the anode, then you'll really have problems getting it out.
10-15-2010, 09:31 AM
Wanna Be Camper
Ditto. and
John & Deb
2011 Flagstaff V-Lite 30WRLS
10-15-2010, 12:35 PM
The anode rod in the water heater is subjected to a lot of heat and the threads really lock together tightly. A heavy duty wratchet or breaker bar is the way to go.
The first time I did mine two years ago, I tried to use an adjustable wrench, the wrench slipped and I cut my thumb right down to the bone on a piece of sheet metal. I still have a scar an inch long as a reminder of my stupidity.
10-15-2010, 12:47 PM
brania
ok I'm not too bright. Of course it's the water heater. thanks all for the advice for the newbie................
andy
10-16-2010, 06:36 PM
Brania,
Don't forget to bypass the water heater and remove your water filter and put the glass back on. Then you should drain the water tank. There should be an access panel in the "basement" to the valve. There is a hose in the sewerage compartment that you can remove the cap, put it in a gallon of RV antifreeze, turn on your water pump and then turn on your faucets until the water turns good and pink. If you do the kitchen and bath sink you will use @ 1 gallon of antifreeze. Put a new bottle of antifreeze on the hose and repeat the process with the toilet (don't forget the sprayer) and the shower. If I have any antifreeze left over I put it in the drains.
George
George and Cindy
Mainers living in AZ (when we're home)
10-16-2010, 06:39 PM
Brania,
When you put th anode rod back in be careful to not crossthread it. It is heavy on the end and easy to do
George
George and Cindy
10-16-2010, 09:43 PM
A couple wraps of teflon tape will prevent leaks and make it easier to remove next time. Just make sure the tank is full of water before turning it on next spring or bad things can happen - don't ask me how I know!
10-16-2010, 11:07 PM
Just a clarification, I think the mentioned socket size is 1 1/16" not 1 1/6". Just finished doing mine.
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
10-17-2010, 07:25 AM
Oops.....my bad. 1 & 1/16th inch is what I meant in my #3 post.
10-17-2010, 08:24 AM
Thanks for catching that. My bad.
10-17-2010, 11:29 AM
Since 2 of us both said the socket size was 1 1/6th, seems to me that it just has to be correct.
Something about the / looking like a 1 to this slightly dyslexic brain.
