Mystery Solved - Propane Detector Alarm during Equalization Cycle
For a couple of years I have had a problem with the propane detector going off whenever the converter went into bulk mode (i.e. High voltage charge rate).
I just thought it was due to the Batteries being under the steps, right next to the detector.
Recently changed the propane detector due to age. No longer getting the alarms!
Detector tests good with the test button.
Haven't tried releasing a gas near it for live test. When I do, I will up date.
2011 Solera 235S
Freightliner Badge
