Most likely you have a bad ground somewhere.
Ground is the wire that goes from the light to the frame, as opposed to the power wire which comes from whatever switch on your vehicle sends the power to the light. When the ground is missing or not making good contact, the power sometimes goes back through another ground wire to another light, through that light backwards until it gets to a light has a good ground. That's why they are dim. I'd check the ground wires on the passenger side tail light.
2011 Traverse LT, 3.6L, FWD
