There is a pump and a check valve, and most likely a 2-way or a 3-way valve, between your main cold water plumbing and your FW tank. And you can see your pump is higher than the bottom of the FW tank. So the low point drains only drain the main plumbing (and not necessarily all of it, depending on it's ups and downs). So the FW tank has its own drain.
2011 Traverse LT, 3.6L, FWD
