Originally Posted by JLeising
Our 2012 has a Lippert “Flush Floor” slide. I have regularly extended and retracted it on the house batteries. I have recently (3 years ago) converted to lithiums, which are stronger, but did the same prior to the conversion.
I too have regularly operated the slide on my TT and have done so since I brought it home in 2017.
I read the admonition in the "Manual" to have shore power or generator running before doing so but kind of ignored it with no issues.
I think the warning is there because so many DO NOT maintain their batteries properly but never notice slide issues because they are most often on shore power. The problem then surfaces during an overnight stop or other instance where shore power isn't available.
Speaking only for my slide (a 10 foot, electric through frame, flush floor type) it draws <6 amp while operating (as measured on my BMV-712 monitor) so any reasonably well charged battery is more than capable of handling the task without assistance.
I now have LiFePo4 batteries and of course they do a great job but my old lead/acid batteries never needed either shore power or generator.
In closing, one may have an issue if only operating with a small (like group 24)lead acid battery that is old, poorly maintained, and has been "off charge" for a while.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
