Old 08-13-2015, 07:25 PM   #21
I think that the OP has miss understood. I highly doubt that is such a thing as a do it your self. Not trying to be a jerk but if you are new at this you may not have understood what the tech had said. I have been involved in many miss communications especially over the phone. Just drive it in there they will fill it. Hell, ever Oregon does not trust you to pump your own gas......
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 08-13-2015, 07:28 PM   #22
Phat Phrog Stunt Crew
elind's Avatar
In Arizona I had the propane pumped into my 30 lb tank and he would of pumped it in place but I had it out before he said it.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-14-2015, 01:13 AM   #23
2007 WildCat 32QBBS
18CrewDually's Avatar
Originally Posted by PolarisGuy View Post
I worked for a large RV dealership for a few years when I was younger. On a freezing cold morning a customer came in to get propane. I had been trained, done it a hundred times, and yet still made a crucial mistake and didn't have the threads on straight due to my hands being so cold. I flipped the on switch and propane covered my entire manhood area hence sending me to the hospital. Needless to say, I was called 'Frosty" by all my other techs after that. Lesson learned.
Hhmmm, Polar Is Guy.
Like most I never have heard of self serve propane. My wife's work is set up for selling propane but they haven't started selling it yet due to no one is trained yet.
18CrewDually is offline   Reply With Quote
Old 08-14-2015, 07:58 AM   #24
Wolverine 1945's Avatar
Originally Posted by Hicks43 View Post
Amerigas supply's all the u hauls with propane. They are trained to fill it for you. If you don't mind where is this uhaul located at. I'm a service tech for amerigas. This needs to be addressed swiftly. Thank you jim
Sent from my iPhone using Forest River Forums 2015 21ss havein fun
RIGHT ON Hicks,,, this dealer needs to be reported to the State !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-14-2015, 08:26 AM   #25
7 Year Class A RV'er
Vince and Charlette: I did some research last night (certainly not exhaustive, but I thought pretty thorough) and I can't find any changes in regulations for LPG in Ohio or elsewhere that would cause the fellow's statement about not being able to fill your tank. I think there is a periodic inspection of tanks permanently mounted in the RV required by some locales (not sure) and I even once heard of a "lifespan" before you had to replace it with a new tank (something like 20 years) due to possible corrosion, but not on a new RV like yours. Have other dealers told you this or just the one?
2015 Legacy SR340 360RB
Old 08-14-2015, 08:30 AM   #26
The law here in Washington is 12 years for the date stamped on the handle of the tank for portable ones, then it needs to be re-certified. Unsure what the rules are for permanently mounted tanks on RV's is. Most fill locations dont even check the date unless the tank looks like junk.
Mike, Lisa and Jake
Old 08-14-2015, 08:48 AM   #27
Pixelbum1's Avatar
Go git 'em Hicks!
It not only needs to be addressed but "they" should be FINED! A HEFTY ONE.
Sounds like a LAZY operation. Tractor Supply also has service for LP and they
do it! Prices are great too!
PS: To underscore the safety concerns...I was standing near the twin 30lb
tanks of my Airstream many a yr ago which had full tanks and were
baking in the sun. I suspect one of the tanks was overfilled perhaps
by an overzealous tech but when I reached up to switch the valve from
one tank to another the overfilled tank decided to "vent" right onto the
back of my hand. I was fairly startled by this(my neighbor two houses
down heard it!) and then the pain hit me! Put me out of commission
for a bit, trust me :[
Pixelbum1 is offline   Reply With Quote
Old 08-14-2015, 08:53 AM   #28
$2.39 a couple of days ago !!!
newbie, propane, tank
