It looks like it ought to fit. The "hard width" (without cushions) is a few inches less. Also appears like it would fit in the door (in pieces) but be sure to check that.
One thing I'd be concerned about is this quote:
Minimum depth required to fit on slide out is 36-1/4" with front of recliner overhanging the slideout
If you're putting it on a slide...is the width of the slide floor sufficient?
Good luck!
Dave
