09-25-2014, 11:40 AM
Side cameras for Jensen VM9726BT
Has anyone added side cameras for the Jensen VM9726BT?
09-26-2014, 03:39 PM
Commercial Member
If you have a backup camera already...there is a video box above the steering column that has inputs for side cameras. We don't route rear cameras to the Jense (although you could) we route them to the rear view mirror monitor.
We use Rear Vision Safety camera and video boxes...so if you bout from side mount cameras you just drill a hole in sac fender, run the wire to the steering column area and plug it right into the back side.
Assuming you actually have a back up camera.
09-26-2014, 05:09 PM
BC, would the side cameras be turn signal activated? Does not look that way from RVC's web site, but I could be wrong.
2014 Solera 24R
USN Retired
09-26-2014, 07:32 PM
Commercial Member
Yes they would. We use the same system on our Solera.
09-27-2014, 06:47 AM
BC, no additional wiring required? Just plug into the box with cameras mounted on correct side? Are your side cameras the ones on the RVS web site?
2014 Solera 24R
USN Retired
09-27-2014, 07:14 AM
Commercial Member
No. You have to tie into the turn signal wire, otherwise no way to know. I'll track down what we use. They are specifically side view cameras. Tiny little things not much bigger than a couple of sugar cubes.
09-27-2014, 02:28 PM
I would be interested in the info. Thanks BC.
2014 Solera 24R
USN Retired
09-29-2014, 10:34 AM
Commercial Member
OK, its Rear View Safety.
Attached are the mounting instructions. We use the MV1 camera. Those should plug right into the video box. There is a wire for the right and left turn signal.
09-29-2014, 03:19 PM
Thanks BC! Those look perfect.
2014 Solera 24R
USN Retired
