I set my solar controller to cut off at 13.2 volts to reduce water consumption by my batteries before I converted my house batteries to lithium. I have a 100 watt panel with a PWM controller I installed about 7 or 8 years ago. After installation I found I was having to add water every month or so to my group 27 factory installed wet cell batteries. Changing the charge cutoff voltage essentially eliminated the water usage.
FYI, Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
