11-09-2014, 08:56 PM
Water in storage compartments - 2015 Forester MBS 24R
Today we traveled about 4 hours from our home (rained the entire drive) to Highlands Hammock State Park, in Sebring, FL. It's beautiful here, however, the weather has kept us from exploring.
This is really our maiden trip, as we only spent one night in it the day we picked it up at the dealership. We were very comfortable traveling, and my husband loves driving it.
As we were setting up camp we found that 4 of the outside storage compartments leaked. We hope it'll be an easy fix. Anyone else have this problem?
Safe travels!
2015 Forester MBS 2401R
No Toad
11-09-2014, 09:14 PM
I've had leakage in the rear compartment of my 24S, short of going to a automotive store and getting some weather stripping to put around to the door. I drilled small drain holes in the compartment where the water was settling which seems to be working so far.
Henry & Tena
11-09-2014, 09:16 PM
How long will you be in Sebring? Where is your home base? We will be in the Davenport/Kissimmee area 01Dec to mid Mar.
11-09-2014, 10:38 PM
Safe travels!
I think this issue was discussed in the Solera forum before. Do a search on leaking compartments on a Solera. I think the poster had a solution.
11-10-2014, 07:22 AM
Hi!
Thanks for writing. We see that there are drain plugs, but there was just too much water to ignore. We never had this problem in our 5er nor have friends of ours with TT's, etc. We hope the dealer can fix it.
Be safe.
No Toad
11-10-2014, 07:26 AM
Hi!
We will only be here a few days. Our home base is Parkland, close to Boca Raton. We are new to Florida, so we have much exploring to do! Our daughter just moved from Waynesville, NC to Knoxsville. We love NC.
Have a safe trip!
No Toad
11-10-2014, 08:04 AM
Thank you! Will check it out....
No Toad
11-10-2014, 09:29 AM
make sure the grey & black tank dump valve handles can be pushed all the way closed
my grey tank handle would only close the within 1/4" of fully closed - turned out to be something that I was able to flush out with the tank empty and while working the handle to & fro while using a hose to spray water into the area. I actually had to undo the 4 bolts securing the valve to turn the handle vertical at times.
11-10-2014, 11:46 AM
Commercial Member
Make sure you push in on BOTH sides of the latches. One side may latch and the other does now which will leave a gap in the seal.
The only other way it would be leaking is if the water is coming UP into the compartment. IE the rotocast is not sealing properly to the wall.
11-10-2014, 12:40 PM
Hi,
We're confident both latches were closed. Sorry...what's a rotocast?
Thanks for your reply!
No Toad
11-10-2014, 12:43 PM
Commercial Member
Rotocase is the gray plastic box that is the actually storage portion.
They "rotate" the mold so that the material flows evenly through all the little nooks and crannies.
11-10-2014, 01:11 PM
Thank you, sir! We'll have the dealer take a look at that.
Appreciate your quick response!
No Toad
11-13-2014, 01:40 PM
We had water in the driver side rear compartment of our new Solera. Took RV to dealer. They sprayed something to seal it. It has basically been water free since fixed by dealer. I understand it was an easy fix.
11-13-2014, 01:48 PM
Thanks very much for your reply! Ours is going in for a few other warranty items in a few weeks.
Best regards,
Mary Ann
No Toad
04-11-2015, 12:54 PM
I found the leak
04-11-2015, 12:58 PM
Originally Posted by dswiss
Super glue it and put a hose clamp around it.
