268RKS Water heater bypass
Thanks to all who pointed me in the correct direction or offered up advice. On my Rainier (a FR custom Vibe build for a large local RV dealer in the pacific NW), the heater bypass is:
1. Located to the lower right of the frig, and the panel is secured by 8 screws. The panel also holds a 110 outlet. I am mounting small cabinet hinges, a magnetic catch and a small cabinet pull knob so access can be easier.
2. the water pump is located in the bathroom sink cabinet behind a panel secured by 4 screws. There I am simply using magnetic catches in the corner and drilled a small 3/4" hole so I can use my pinkie finger to pull it out.
Seattle, WA
2017 Rainier 268RKS by FR
2014 Ford F350 King Ranch DRW FX4
Fastway e2 WD hitch w/ 2-Point Sway Control - Round - 10,000 lbs GTW, 1,000 lbs TW
