Old 07-08-2016, 12:35 AM   #1
BrianMcD's Avatar
272BHS black tank reads full
Hello, my Black Tank reads as 2/3 full and gray 1 and gray 2 read empty. We have not used the toilet but only bathroom sink and kitchen sink. Isn't toilet only suppose to fill Black tank. Any help on what goes to Gray and black would be appreciated. Thanks in Advance.
BrianMcD is offline   Reply With Quote
Old 07-08-2016, 12:50 AM   #2
2007 WildCat 32QBBS
18CrewDually's Avatar
Unless you can see the plumbing there's only 1 way to know for sure.
Hook to the sewer with a clear fitting inline.
Dump all tanks.
Turn on the shower faucet for 2 minutes.
Open valve and note which one expels the water.
Repeat with the toilet, then kitchen sink, taking note which tank valve.
18CrewDually is offline   Reply With Quote
Old 07-08-2016, 04:43 AM   #3
ilmor's Avatar
Is the unit brand new and you're sure the toilet has never been used?
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
ilmor is offline   Reply With Quote
Old 07-08-2016, 04:49 AM   #4
kdp1897's Avatar
Can you see into your black water tank from the open toilet valve? If so, you should be able to see water if the tank is reading 2/3. Otherwise, it's possible the sensor were connected to the wrong level meter.
2017 Rockwood Ultra V 2618VS
2017 GMC Sierra 1500 SLT Crew Cab Z71, 5.3 EcoTec V8
Nights Camped: 10 (so far) in 2024; 28 in 2023
kdp1897 is offline   Reply With Quote
Old 07-08-2016, 05:26 PM   #5
My 272 has read full since the first use might be an issue with the sencer I have used a wand and even a special cleaner .I have learned to empty my tank every other day when camping for extended time.
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 07-08-2016, 05:30 PM   #6
Tom48's Avatar
[QUOTE=BrianMcD;1251946]Hello, my Black Tank reads as 2/3 full and gray 1 and gray 2 read empty. We have not used the toilet but only bathroom sink and kitchen sink. Isn't toilet only suppose to fill Black tank. Any help on what goes to Gray and black would be Do you ha. Thanks in Advance.[/QUQte
Do you have separate hook up points for the sewer hose, or all three valves coming out same hookup.
ARE YOU SURE?
IN A recent post member noted. After back flush ran out on the roof that his poop valve and or poop sewer hookup was neatly concealed under the frame. He had drained grey one and grey two only. I turn off the water pump and look down the toilet to verify black tank level.
I assume the unit is not new and probably someone was doing a poor job of tank flushing and there is STUFF DRIED ON THE SENSORS.
Tom48 is offline   Reply With Quote
Old 07-08-2016, 05:40 PM   #7
I also have a VIBE 272BHS. The shower has its own tank, ~29 gal, usable. The toilet and the bath sink share the black tank, ~29 gal usable. The galley sink is on its own, ~33 gal usable. All measured with the unit level. I have not tested the outside sink.
efeisty is offline   Reply With Quote
black, black tank, tank
