Old 01-22-2018, 12:39 PM   #1
A/c Fan always on
The A/C fan runs continuously, regardless of mode. The only way to stop the fan is to have all off. The fan runs even when the furnace is on? Any ideas?
2017 Forest River Vibe 221RBS.
GeoD is offline   Reply With Quote
Old 01-22-2018, 12:42 PM   #2
Fulltime family RVer
You have to set the fan to "Auto" on the thermostat:
Help! A/C Comes On When Heat Comes On | Learn To RV
Old 01-22-2018, 12:43 PM   #3
Mr. Dan's Avatar
Yes, this question is asked 2-5 times per week here. If your thermostat is like most, you should click through all modes (Off, Cool, Heat, FAN) and stop on FAN. Use the + key or the - key to cycle from LO, HI and stop on AU for Auto. Then the A/C fan will not run when the furnace does.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 14; booked = 14
Old 01-22-2018, 12:52 PM   #4
To add to what has already been said, this is not a problem but rather a feature.
The manufacturer allows you to run the A/C fan with the furnace to help distribute the heat better. (heat rises)
These features are spelled out in the thermostat manual.
if you don't have one, they can be found online or in the library section here on the forum.
Heating & Cooling Library
Days Camped: '17=30 '18=51 '19=58 '20=83
fan
