Old 03-16-2018, 10:16 PM   #1
Ac problems
Second time out in our new 2018 308 Vibe, the main air conditioner works but when you close the main vent to have the ac go through the vents it doesnít work. Any ideas?
Big-un51 is offline   Reply With Quote
Old 03-17-2018, 02:59 PM   #2
RolltideRoo's Avatar
Ok, the air doesn't blow out the vents or the unit shuts off?
RolltideRoo is offline   Reply With Quote
Old 03-17-2018, 03:00 PM   #3
If still runs but no airflow out vents, there may be a blockage. Did it work the first time?
Old 03-17-2018, 03:02 PM   #4
It worked the first time but it wonít come out of the vents.
Old 03-17-2018, 03:04 PM   #5
If a dealer isn't close, pull the ceiling panel to check for blockage, may be some foam insulation blocking, you can also pop the vent closest and feel for blockage, too.
Old 03-17-2018, 03:05 PM   #6
You tube shows a lot on disassembly
Old 03-17-2018, 03:06 PM   #7
Ok thanks Iíll give it a try.
Old 03-19-2018, 07:53 PM   #8
Did you find the problem?
Old 03-19-2018, 08:07 PM   #9
Iím taking it in Monday my wife doesnít want me to mess with the warranty. Thanks for your help.
Old 03-19-2018, 08:08 PM   #10
No worries, why it has a warranty
Old 04-03-2018, 02:33 PM   #11
What was the diagnosis?
Old 05-23-2018, 06:34 PM   #12
I have the same problem and was a blockage of the vent outlet with the foil tape from the manufacturer installation. Easy remove the main blow down cover and cut open the vent foil!
Omar is offline   Reply With Quote
