Old 06-30-2022, 12:06 PM   #1
Air Conditioning Vibe 25RK
We have a 2021 Vibe 26RK with one air conditioner. It is wired and braced for the second one. Can we get by with the single, or do we need to go ahead and have the second one installed ?
ranger1055 is offline   Reply With Quote
Old 06-30-2022, 12:13 PM   #2
No. Especially if it is a 13.000 btu unit.
Unless all of you travel is done in times when ac is not really necessary.
We live in Dayton Ohio. North of you.
tomkatb is offline   Reply With Quote
Old 07-01-2022, 08:05 PM   #3
As a 26RK owner, if you have the means get the 2nd A/C. Those big windows on the RK let in all kinds of heat even with reflective insulation covering the sun side. I also like the peace of mind of having 2 should one go bad a thousand miles from home. Happy travels!
2022 Vibe 26 RK
2019 Ram 2500
snoopinaround is offline   Reply With Quote
Old 08-07-2022, 09:44 PM   #4
I have 2022 with 15 btu. Will freeze you out and strong ac to me is a must.
Speedrik is offline   Reply With Quote
Old 08-15-2022, 02:38 PM   #5
Hi
We have a 25 RK, I put second air conditioner myself. It was a easy install, just cut the ceiling where the frame bracing is already installed,the cut out, set new air conditioner over opening and everything else is done inside. A easy installation.
Pepsione1
Vibe26rk is offline   Reply With Quote
air conditioning, vibe
