Old 07-02-2018, 07:59 PM   #1
alain h's Avatar
Bad sway on the highway
We have a brand new 224 Rls vibe
We had our TT on the highway for a couple of times now
And both time Iím having a very hard time keeping this thing on the road due to the severe sway
In Manitoba our main highway is east west and of course 75 % of the time the wind is from north south
So cross wind all the time
My tow vehicle is a brand new 2017 xlt with full tow package
I have to say itís a bit of a joke what ford tow package is
The first thing I replace was the tire going from a koyotires to BF Goodrich TA k02
I run them on 55 psi when towing
My TT tire are Chinese Castle Rock they appear to have very soft side walls the are inflated to 50 psi as per spec .
I have you topical equalizer system with one sway bar control
Makes no difference
The max speed on our highway is 100 k today I had to slow down to 85 to 90 to keep it on the road
You canít keep your hand off the wheel, have to conter steer all the time or it will put you in the ditch
I see other units passing me with the same truck and bigger rigs then mine
The hitch was install at the dealer
Iím thinking of putting air suspension on my truck next year
I have included some pictures
Anyone else with the same problems
Or ideas
This is not my first TT
But this one is a hand full to steerClick image for larger version
ID:	178111Click image for larger version
ID:	178112Click image for larger version
ID:	178113Click image for larger version
alain h is offline   Reply With Quote
Old 07-02-2018, 08:05 PM   #2
First thing to check is tongue weight. Light tongue weight will make for a miserable tow. Second you will need to double check loading. Too much or too little transfer could be causing you troubles.
donniedu is offline   Reply With Quote
Old 07-02-2018, 08:25 PM   #3
crunchman12001's Avatar
You will want to be a little tongue low, off level to increase weight. Do you have a pic of your rig hitched up showing the trailer and truck?
On a side note, get rid of the china bombs ASAP. A new set of quality tires is going to be a fraction of the cost to repair your trailer in the event of a blow out.
2015 F-250 FX4
Old 07-02-2018, 08:25 PM   #4
alain h's Avatar
Explain transfer ?????
Old 07-02-2018, 08:26 PM   #5
alain h's Avatar
And I do not have a light tongue weight
Old 07-02-2018, 08:40 PM   #6
You may not be transferring enough weight to your front wheels of your truck. (WDH not set up properly)
You might have a level trailer but the trailer may be rear heavy. (causes sway)
You need to be tongue low by about an inch to shift more weight forward.
A picture tells a thousand words. Post a picture of your rig hitched up so we can see the entire truck and trailer.
Also, not the best WDH the dealer sold you. I suggest an Equalizer 4 point. It will take you from white knuckles to 2 finger driving.
https://www.etrailer.com/Weight-Dist...ll-description
2015 F-250 FX4
Old 07-02-2018, 08:43 PM   #7
alain h's Avatar
Will try to find a picture
Here it is
Old 07-02-2018, 09:10 PM   #8
Your set up looks good there alain h. You would need to go to the scales to see where you are at with weight transfer. You can try to bring the chains up a link but the scales would be the best.
I had a chain hitch with my old trailer and nearly rolled it from sway. I always had double fist'ed white knuckles. Horrible experience until I switched to the Equalizer 4 point. 2 finger ride until I sold it and went to a park model.
So, try the scales and post the results. You can search "cat scale" for proper procedure. If the results are ok, I would try the Equalizer. (4 point sway control)
You say this is not your first trailer? What prevented the situation you have now? Different truck? Hitch?
2015 F-250 FX4
Old 07-02-2018, 09:27 PM   #9
alain h's Avatar
Yes
I had a ram before and a smaller rv single axle
Old 07-02-2018, 09:36 PM   #10
Well, the Ford should have zero problems pulling 5K worth of trailer. I would go to the scales or buy a new, better WDH like the Equalizer 4 point.
Good luck!
2015 F-250 FX4
Old 07-02-2018, 09:55 PM   #11
With the "Spread Axles" you have on your unit the Only way to know TW is Scales! If you don't have 10-15% Tongue Weight you will induce Sway! Youroo!!
Old 07-02-2018, 10:07 PM   #12
alain h's Avatar
So how do you weight it properly
Old 07-02-2018, 10:15 PM   #13
Truck Stop "CAT Scale or Feed Mill! Have Everything the Same as if you were going Camping,Food /Water and all! Youroo!!
Old 07-02-2018, 10:29 PM   #14
glsimms's Avatar
Here's more info for you:
How to Weigh a Travel Trailer | Learn To RV
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 07-02-2018, 10:31 PM   #15
tonyz1's Avatar
All great points above. I wanted to just ask if the OP is using the trucks built in sway control or has it turned off? On our F-250, I have to remember to turn the sway control off each time I start the truck when towing or the truck really acts " squirrelly". It seems to act against our Husky Centerline hitch. Just my observation and wondering if it could be a factor.
Sent from my SM-T580 using Forest River Forums mobile app
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
tonyz1 is offline   Reply With Quote
Old 07-02-2018, 10:48 PM   #16
Coach
Although less likely than other points already mentioned, might not hurt to give suspension, brakes, bearings, and lug nuts a look over.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-03-2018, 09:09 AM   #17
alain h's Avatar
This could be possible
I didnít turn it off
Will look in to that
It may act against the sway system
Old 07-03-2018, 09:17 AM   #18
Scoundrel
HangDiver's Avatar
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 07-03-2018, 09:21 AM   #19
jd50i's Avatar
Your setup looks identical to mine just branded differently. I would also agree it is your weight distribution, I do not have sway problems with my 2016 F150 XLT and I do not turn the sway control off.
If you do turn it off, be careful, if the truck was dampening sway it could be a lot worse with the system off.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 07-03-2018, 09:32 AM   #20
Phat Phrog Stunt Crew
elind's Avatar
I would try to tighten up chains on the arms and do a trial run. I remember with my first RV I had to tighten it up to put more weight on the front wheels. It went from wiggle/wiggle to two finger driving.
2014 Wildcat 327ck
elind is offline   Reply With Quote
sway
