Old 03-13-2020, 10:16 AM   #1
Does anyone use stabilizers on the Vibe slide.
Was wondering if anyone is using stabilizers on the Vibe's slideout. I saw them in a store, seems like they might be worthwhile, but wanted to get the hive input first.
Thanks in advance.
Desdinova is offline   Reply With Quote
Old 03-13-2020, 10:22 AM   #2
bedubya's Avatar
IMHO slide stabilizers are a solution in search of a problem.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is offline   Reply With Quote
Old 03-13-2020, 10:24 AM   #3
Slide stabilizers are typically considered a bad idea for pretty much all modern trailers. They can actually cause more problems than they solve.
Iwritecode is offline   Reply With Quote
Old 03-13-2020, 11:46 AM   #4
From what I have read, the modern slides need to hang in order for them to seal. If you put a support under them and raise them just a little, you may find water leaking around seals.
Wildwood 31KQBTS
Ford F250 6.7L Diesel
kellydthompson is offline   Reply With Quote
Old 03-13-2020, 12:33 PM   #5
" a solution in search of a problem."
That's awesome. Thanks, everyone.
Old 03-13-2020, 12:54 PM   #6
bikendan's Avatar
Using slide supports will possibly void your warranty, as RV manufacturers warn not to use them.
Slide supports are leftovers from the early days of slideouts when the technology was new and there were many issues. The modern slideout shouldn't need them.
Equalizer WDH
Old 03-13-2020, 02:44 PM   #7
Thanks in advance.
I use one on each side, but not tight.
garyp1951 is offline   Reply With Quote
Old 03-13-2020, 03:29 PM   #8
Tundra 2014
Slide support
I agree, bad idea. We tried them. I did not feel it helped enough for the potential for damage. Also, after a day camped I had to crawl underneath and tighten as they sunk into ground. This was w/ a 2"X 12" underneath them. Switched to X scissor chokes which did a better job on our 27VSL, similar trailer to yours. Cleaner and better option than carrying around 4-jack stands and boards.
Tundra 2014 is offline   Reply With Quote
Old 03-13-2020, 03:49 PM   #9
ARLO
Never used them, never had a problem.
rlocicero is offline   Reply With Quote
Old 03-13-2020, 05:52 PM   #10
I bought two and now have 2 expensive paper weights. A long shot posibility is if you use them and one or both tires on thatt side loose air pressure, you will have tremendous pressure on the slide which can severly damage or destroy the slide mechanism.
hshaynes is offline   Reply With Quote
slide, stabilizer, stabilizers, vibe
