The front stabilizing jack doesn't work, and we know nothing about electrical systems. If you know where the fuse for it is on a 2015 Vibe 268RKS, and what tool I can use to lower it manually, I would appreciate the help with troubleshooting. Thank you in advance.
My stabilizer has an inline fuse. it comes off the battery then goes to the motor. There is a red rubber housing in the shape of a blade fuse. The top pops open and the fuse is inside. I don't know if there is a manual override sorry.
If they are Lippert Stab Jacks on the opposite end from the Motor the shaft has a "Drive Pin,your unit should have came with a Crank that has a hollow socket with a Slot that you use to "Crank" the jacks with! Youroo!!
