Old 01-22-2024, 07:12 PM   #1
Furrion range spark
Have a 3 burner stove , back two spark to light. Front one sparks every 3rd or 4th try. Cleaned the ignitor, it isn't bent, propane is fine. Before I order a part would like to know if I am missing something.
Boowillie is offline   Reply With Quote
Old 01-22-2024, 08:55 PM   #2
Close the gap?
It could be that the spark gap is just a bit too wide and the spark doesn't jump every time. Take a long-nose pliers and carefully bend the electrode to close the gap just a little bit. The longer the spark, the more it is exposed to the flame.
Don't hold the electrode you are bending near the porcelain insulator. It is easy to crack those.
Larry
Larry-NC is offline   Reply With Quote
Old 01-23-2024, 09:19 AM   #3
I get no spark at all, than after a few tries it sparks. The gap looks the same as the back burners.
Old 01-23-2024, 09:28 AM   #4
Swap wires?
Willie, does your range have one spark unit with wires to all the burners, or a separate sparker for each burner? Are you able to swap the wires between the front burner and one of the back ones?
If the symptom moves, it's the spark circuitry. If it stays, it's the electrode.
Larry
Old 01-23-2024, 09:36 AM   #5
Spark
I will check it out by switching wires if possible.
furrion
