There have been many posts about crushed or misrouted ducting. Even some with the ducting disconnected. Not at all uncommon.
With that said, shorter duct runs will blow more air while longer runs suffer from resistance within the ducts.
Many put an adjustable register on shorter runs to maximize airflow to the longer runs. Just be sure you don't choke off too much flow that the furnace overheats.
