You have really low voltage on your battery. Since this is a 2016... check battery condition, any crud on top of battery, terminals clean, renew connections at frame ground and battery power switch. Now, that you did this, is your converter putting out sufficiently to keep battery up?
In troubleshooting anything, it's from the easiest, most accessible things first...always. pulling furnaces is a pia
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
