04-18-2017, 09:52 AM
#21
Left Coast
The amp is where the cable is attached to wall inside....Has a LED light, green or red, and a little push button to turn amp on or off....Light off---amp off
04-18-2017, 10:00 AM
#22
Thanks bob
04-18-2017, 10:01 AM
#23
our Verizon hot spot works/worked great at cg that had bad or no wifi, ... when we got the new iphones we dropped the hot spot off the account and use the iphones as hot spots, ... they work great and actually right now at home, we're using them again for wifi, because we've lost our internet feed from Time Warner Cable and they can't come out until Thursday, .... the iphone works as a great wifi backup at a time like this, ....
04-18-2017, 10:09 AM
#24
So Verizon has unlimited data for hot spot?
04-18-2017, 10:11 AM
#25
Most smart phones have the hotspot option. Easy and convenient. Just have to double check your data plan for any limits.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-18-2017, 10:16 AM
#26
Thank you.
04-18-2017, 10:24 AM
#27
no, .... but Verizon does have an unlimited program, .... we are not on it, but do have a data program large enough for us to use it when needed in cg and to use as we are at this time at home, ...
04-18-2017, 10:25 AM
#28
Constantly Confused
More info, please.
https://www.verizonwireless.com/inte...id=57663203847
This only works if you have cell phone coverage. Many places we camp has *nothing*, no service at all.
04-18-2017, 12:20 PM
#29
Citrus County, Fl.
Verizon unlimited works best with a signal booster and a verizon mifi so you are not using the data from the phone. Even though it is unlimited it can be slowed down if the cell tower is busy.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
04-18-2017, 12:36 PM
#30
04-18-2017, 12:41 PM
#31
Canadian Member
The amplifier is the little switch back of tv?
Here is a picture of the wall plate in my TT. The little black button turns the antenna amp on and off.
04-18-2017, 05:39 PM
#32
Originally Posted by bob caldwell
If you want to test at home, you'll need a cable and connector........Undo cable at tv in house, join cables together, connect cable to trailer outside cable connection......Enter TV menu, set to cable, scan for channels, watch TV...The antenna amp will need to be off
Bob, I connected the cable to xfinity box to cable on trailer, amp off and tv on cable, I think I'm missing something.
04-18-2017, 07:01 PM
#33
Is off
04-18-2017, 07:04 PM
#34
I connected to one off my xfinity box inside home,
04-18-2017, 07:05 PM
#35
Then to my cable input outside TT and hitting auto scan
04-18-2017, 07:16 PM
#36
04-18-2017, 07:18 PM
#37
Left Coast
Can you skip trailer wiring?
04-18-2017, 07:41 PM
#38
Nope
04-18-2017, 07:47 PM
#39
Left Coast
How is one going to make sure trailer wiring ok if you can't first make the system work without it?
04-18-2017, 08:04 PM
#40
I have a Verizon acct. I use my android phone as a hotspot if the campground wifi is crappy.
2011 Traverse LT, 3.6L, FWD
