Old 04-14-2021, 04:04 PM   #1
Leaking shower enclosure
I have a 2021 22' Vibe with a corner shower. The shower enclosure has a quarter round sliding door unit. It came from the factory leaking like crazy. I took it back to the dealer (Bill Eads) and their solution was to hap-hazardly squirt silicone along the interior edges in a failing attempt to solve the problem. Instead of battling the inept service department I plan on trying to fix it myself. I would like to completely remove the enclosure and reinstall it with the sealant properly applied, but I am hesitant to start prying the aluminum track away from the shower side walls. Has anyone had experience in removing an enclosure without damaging anything in the process.
Blu Bug is offline   Reply With Quote
Old 04-15-2021, 08:23 AM   #2
SeaDog's Avatar
I assume you are saying its leaking from the bottom track? I don't believe I would remove the track instead I would use something like a razor knife and clean the area very well then reseal it.
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-16-2021, 05:28 PM   #3
The leak is at the shower door's side where it attaches to the wall panel. I'm being to wonder if the shower door was designed to only have exterior caulking/sealant.
leak, show, shower
