Old 12-30-2017, 12:56 PM   #1
low point water drain for winterizing
Forest River Vibe 308 bhs where are the low point drains located?
popsten is offline   Reply With Quote
Old 01-02-2018, 10:35 AM   #2
Found what i was looking for on my own...thanks for viewing. will make some changes to make it easier.
Old 01-02-2018, 10:46 AM   #3
Please post where they are so others can benefit from the knowledge.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 01-02-2018, 11:51 AM   #4
Fresh Water drain located under Vibe 308bhs straight across from fill point
The Low Point drains are located at the bathroom sink and the lines protrude thru the floor underneath Camper between rear tire and rear entry door. You have to physically remove the two caps from the hot[red] and cold[blue] lines to drain. I will be adding cut off valves to the lines. 5 degrees realfeel is no fun laying under your camper with frozen hands. Also removed plug from Water Heater and drained it also.
Old 01-13-2018, 01:40 AM   #5
If you havent already, Home Depot has pvc ball valves cheap. Thats what I used.
hshaynes is offline   Reply With Quote
drain, water, winter
