Our electric slide has a roll pin through the shaft that the manual crank goes over so it's not a socket. In our last unit it had a hex head that was 3/4" so a 3/4" socket fit it fine. I just had a couple of long extensions in order to reach it.
When you post the pics try to get one of the end where the manual crank goes.
Gotta go campin!
I looked at the link above. That socket is for a 1/4 drive. That will work you to death if it even holds up. I do hope it works.
That socket fit my manual rods by widening the slot slightly with a cut-off disc.
I tried it with a cordless drill instead of a 1/4" ratchet.
It moved the slide(s) just fine.
F&AM Lodge 358 Somerset, PA - JAFFA Shrine - Altoona, PA Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=90
