Old 04-20-2017, 01:30 PM   #1
Lourdita6869's Avatar
New Vibe owner
How you turn on oven?Click image for larger version
Lourdita6869 is offline   Reply With Quote
Old 04-20-2017, 01:38 PM   #2
New Vibe owner
how do you light oven.
Old 04-20-2017, 09:08 PM   #3
If it's like my oven, you have to light the pilot first. In order to light the pilot, you have to turn the knob to pilot, then push in and hold until it lights the pilot light. I would make sure you have gas at the stove first by lighting a burner.
foretm is offline   Reply With Quote
Old 04-21-2017, 11:27 AM   #4
Yes, it is much easier to make sure you have gas to the stove by lighting the burner.
I usually hold in the knob for a little while so I don't waste the lighter fluid. So little propane comes out at a time, it takes a little while to light.
KKonyha is offline   Reply With Quote
Old 04-21-2017, 01:54 PM   #5
Thank you , it's on.
Old 04-21-2017, 01:55 PM   #6
Thanks [emoji106][emoji106][emoji106]
Old 04-26-2017, 05:28 PM   #7
You have light the pilot manually
stevenconnie is offline   Reply With Quote
Old 04-26-2017, 05:38 PM   #8
Thanks [emoji106][emoji106]done.
Old 04-28-2017, 06:13 PM   #9
I can't believe, for all of the advancements in RVs, that process can't be as easy as lighting the burners
54GFL is offline   Reply With Quote
