Old 11-25-2018, 12:19 AM   #1
alain h's Avatar
No AM station on my radio
Why is it that I can get FM stations no problem but absolutely no AM stations
Is their a fix I can do
We have a brand new Vibe 24rls
alain h is offline   Reply With Quote
Old 11-25-2018, 02:35 AM   #2
bikendan's Avatar
Neither our 2007 HTT or our current 2016 TT radios got good AM reception.
One was a Concertone and the newer one is a Jensen.
Equalizer WDH
Old 11-25-2018, 07:10 AM   #3
KyDan's Avatar
Are there still AM station???
A wild guess-- some receivers have 2 separate antenna connections. One is for
AM and another for FM. It's possible your AM connection has nothing attached to it?
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-35
Old 11-25-2018, 07:24 AM   #4
Oaklevel's Avatar
I was going to say the best way to get AM stations is go back in time to the 1960s.................... My car can not get them very well either....... At home with a good radio I get 2-3 on a good day.
Not trying to be smart but two things the radios and antennas in campers are cheap at best, but can you receive AM stations on another Radio ??? if not it is not the camper.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 11-25-2018, 07:29 AM   #5
Mine doesn't get them either and I have the magnadyne (????)I need to dig back there and see what's going on.
2017 Vibe Extreme lite 21FBS
2008 Silverado 2500 6.6 diesel
Dan1969 is offline   Reply With Quote
Old 11-25-2018, 08:48 AM   #6
We’ve had two different radios in two different rigs, no AM, hardly any FM either....
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 11-25-2018, 09:08 AM   #7
Coach
This in concert with AM not having the transmission range of FM and is much easier interfered with by other over the air signals.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 11-25-2018, 09:08 AM   #8
Hi,
I greatly improved AM reception by clipping (alligator clip) a dangling piece of 6' copper wire to the stubby outside antenna on my Silverback.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 11-25-2018, 09:36 AM   #9
DAISY BOYKIN's Avatar
No am stations
I will try to explain this again, Two things can cause poor AM/FM radio
station reception.
1. Check to see if the antenna cable (JACK) is plugged into the radio case.
2. No ground on radio case, the case has to have a ground connected to Chassis or frame of what it is mounted in for the antenna to work properly.
A lot of times the AM/FM antennas are isolated from grounding by the
installer not knowing that installing the antenna in fiberglass/ABS/plastic
thus does not make a ground connection.
How do I know this, 28 Years of selling, servicing, installing AM/FM radio
systems in all kinds of installations.
30 Years of selling, servicing, Installing TWO-WAY communications!
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 11-25-2018, 09:50 AM   #10
Hi Daisy,
I am always open to learning, so if you could help me a little, that would be great.
How can I check the mass of wires in the back of my radio to ascertain if it is properly grounded? My antenna is mounted in fiberglass, but I have checked to be sure the antenna lead is firmly plugged in.
And if it is not grounded properly, what should I ground it to? Sounds stupid to ask, but I don't want to assume tapping into the power ground wire is all that has to be done.
Thanks.
Rich Phillips
Rich Phillips
Old 11-25-2018, 10:11 AM   #11
Flybob's Avatar
The FM and AM antenna are two separate items. Check the back of the radio. The AM antenna is usually a single wire attached to the back of the radio. It is delivered coiled up with a twist tie. Make sure the ant is extended. It can be hanging down or tied up, but needs to be uncoiled.
The FM antenna is generally a coax that plugs into the radio. In many cases it is connected to the splitter from the roof top TV antenna.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-25-2018, 10:25 AM   #12
SPRING IS COMING!!!
BriaBeck's Avatar
I have the same problem with our TT.
We have the el cheapo "Drive" entertainment system.
I squawked the issue when we took our camper in earlier this month for its "Forever warranty" inspection. They took me back in the shop, inside a big metal building, and the AM was working. Not very well, but it was working, very marginally picking up a couple of stations. The guys there said "And this is inside a metal building... nothign wrong with it. ((You're Nuts))" Got it back home, and same as before... absolutely nothing but static.
Moral of the story: Build yourself a big metal building to put your camper in anywhere you go, and your AM stations will come in just fine.
Brian & Becky
__________________________________
2018 Avenger ATI 27RBS, pushing a 2002 Chevy Silverado 2500HD Duramax w/ Allison 1000
BriaBeck is offline   Reply With Quote
Old 11-25-2018, 01:02 PM   #13
rracer5's Avatar
The Jensen radio on my first Wildwood TT had a separate antenna on the roof.
The Jensen radio on my second Prime Time Lacrosse had a coax cable connected to an adapter which apparently used the omni-directional Tv antenna for reception.
But, the biggest issue is, good connections and solid grounding as mentioned earlier. Sometimes, you just have to run your own ground wire.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-25-2018, 05:36 PM   #14
Senior Senior Member
raytwntrvlr's Avatar
We get good to very good FM reception but zero on the AM side. I carry a nice portable for that plus we have a Sirius portable radio that gets everything we need. The Sirius is great in that we can use it in our TV as well.
2015 Flagstaff Super V 26VFKSS Emerald
raytwntrvlr is offline   Reply With Quote
Old 11-25-2018, 05:45 PM   #15
alain h's Avatar
I have great reception for the FM stations but nothing for AM a have a spare radio work just fine on AM
Will have to drop the radios in the spring and have a look
Old 11-25-2018, 08:09 PM   #16
justpassinthru's Avatar
Radio in TT
Hi folks, have a question, i have a travel trailer and removed the screws from the radio and when i pulled it out i saw that the radio antenna was rolled up and with i tie rap. What can i do to get more fm stations and clarity without installing a roof or any sort of outside antenna? Any ideas someone has used? That will receive better reception Thanks looking forward to all suggestions. Jim M
justpassinthru is offline   Reply With Quote
Old 11-25-2018, 08:16 PM   #17
Mr. Dan's Avatar
See post #11. Apparently, it's the AM antenna that's coiled up. Uncle Gene's FM antenna was almost coax-size and not coiled it - it just wasn't plugged into his radio.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 14; booked = 14
Old 11-25-2018, 08:45 PM   #18
What works for us is to turn OFF all LED lights. After we do that we can get AM stations. FM doesn't seem to be a problem.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 11-25-2018, 09:27 PM   #19
Mslaman's Avatar
Are you parked under a bridge?
I have a friend that does AM talk radio. While traveling any time we go under a bridge or through a tunnel, all you here is static.
Mslaman is offline   Reply With Quote
Old 11-25-2018, 09:40 PM   #20
bikendan's Avatar
How's does this help the OP?
Equalizer WDH
radio
