Old 07-01-2018, 08:30 AM   #1
Remote Slide problem
Hello all. New to the forum. We recently purchased a 2017 Vibe 268RKS. Weíve had it out a couple of times with no issues. When getting ready to set up this weekend I noticed the slide will not work with the remote. Works fine with the switch on the wall. I do hear a solenoid click but no movement. All other remote functions work. Any ideas? Not a big deal but it bugs me when something doesnít work as it should. Thanks in advance. Iíve learned a lot on this forum as previous owner didnít know much. Probably why he sold it after a year and 2 short trips.
MDJ59 is offline   Reply With Quote
Old 07-02-2018, 11:08 AM   #2
You have a blown fuse. Look where you hear the clicking. I would change it out with a breaker that is self resetting.
Vibe 308BHS - 2017 F250 6.7
Krazo is offline   Reply With Quote
Old 07-28-2018, 04:26 PM   #3
RolltideRoo's Avatar
Iíve had this too when itís not connected to 120v, the fuses donít blow on the 2018s but a relay foes shut it down, Iíve had it twice, fuses were fine. If your stats are a little low it causes an overload.
RolltideRoo is offline   Reply With Quote
Old 08-04-2018, 08:31 PM   #4
Thanks for the advice I finally had time to look for this fuse. It was in a separate fuse panel behind a lower panel in the bathroom linen closet. Fuse fixed the problem.
Old 08-07-2018, 09:18 PM   #5
cool mine never blew.
Old 08-09-2018, 11:21 PM   #6
Mine blows every time I let the slides in if I hold the remote too long. I usually let the slides almost all the way in and stop just before the stop and finish the retraction with the hard wired switches.
remote, slide
