Old 03-21-2018, 08:17 AM   #1
replacement 12v LED fixtures for 2016 VBT308BHS
My 2016 VBT308BHS has some fixtures that need replacement. Looks like the previous owner tried to fit in the wrong bulbs and the connectors seem damaged.
Is there a good source for exact replacements?
Thanks!
Kremlar is offline   Reply With Quote
Old 03-21-2018, 08:44 AM   #2
cavie's Avatar
Thanks!
Look on the fixtures for manufactures name and part # on the back.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-21-2018, 10:10 AM   #3
I did take down the fixture and look, but the only marking I saw was a very faint "RV LUMINAIRE VR 30520" and a search did not bring up anything specific.
This is the closest thing I found based on the photo and dimensions:
https://www.ebay.com/itm/12V-DOUBLE-...NV8yMy&vxp=mtr
The bulb looks different, but it says "921" which is the same bulb type my existing fixture uses.
I think I will order one and give it a try. Just trying to find something that fits the same mounting holes, etc. if possible.
Thanks!
Old 03-21-2018, 12:24 PM   #4
cavie's Avatar
Thanks!
Is this it?
Old 03-21-2018, 12:49 PM   #5
Originally Posted by cavie View Post
Is this it?
Did you intend to post a link?
Old 03-21-2018, 12:50 PM   #6
cavie's Avatar
yes. https://www.amazon.com/Kohree-Ceilin...+light+fixture
Old 03-21-2018, 12:56 PM   #7
No, this is it:
www.techav.com/misc/rv_fixture.jpg
Looks very close to the one I linked. I also reached out to Forest River to see about getting an exact replacement from them.
Old 04-05-2018, 06:59 AM   #8
FYI, Forest River had replacement fixtures available for cheap money. I think they said around $6? However I was able to pry out all of the bad/incorrect bulbs and my fixtures are now working well with the correct LED bulbs.
led, replacement
