Old 01-19-2020, 03:55 PM   #1
Slide seal
Ok so im looking to replace the seals on my 21FBS slide, looks like they have started to separate with the time. I have attached a pair of photos, just looking for advice if it's easy to do, or if it has to be taken to a service center. Keep in mind im handy but I am not very good at dealing with the slide cable pulley system. Thanks for any input, links or experiences.
ID:	222036   Click image for larger version
Dan1969 is offline   Reply With Quote
Old 01-19-2020, 08:58 PM   #2
Is the seal you are pointing to running along the bottom edge of the slide?
hshaynes is offline   Reply With Quote
Old 01-19-2020, 09:15 PM   #3
No, it's the side. The photo is just sideways. Both sides are just cracked, looks like it's called a "swiper" seal, just wondering if anyone has done it on their vibe
Old 01-19-2020, 10:31 PM   #4
I have not experienced any problems with mine. I do keep them lubed, at least twice a year. Sorry I can't be of help.
Old 01-20-2020, 05:03 PM   #5
hdjimmi's Avatar
What do u use to lube/treat them with
Retired and loving it
hdjimmi is offline   Reply With Quote
Old 01-21-2020, 08:44 AM   #6
Here are the lubes I carry currently. I probably will wind up using only the one on the left as the others are used up. If you do not want the mess from spray around windows, use petroleum jelly, lightly. Click image for larger version
Old 02-23-2020, 10:37 AM   #7
DO NOT USE ANYTHING PETROLEUM ON THE SEALS. It will swell and rot them. The maintenance sprays are silicon base and are designed to protect theses rubber products.
Bill Burke
Firefighter, NREMT
2020 Forest River Vibe VBT32BH
05 Chevy 2500HD 4x4 6.0
Wife W/4 dogs & 12-16 chickens
Mandog is offline   Reply With Quote
Old 02-23-2020, 11:14 AM   #8
Iíve used this for several years.. seems to work for me..
https://smile.amazon.com/Thetford-Co...e%2C259&sr=1-7
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
seal, slide
