Old 07-26-2019, 05:25 PM   #1
stability in question
Our 2019 Vibe 26RK is set up at a campground at a lake, and will not be moved. We have a seasonal set up, and for a mere $150 we can leave it there through the winter and just open it up in the spring. I have a question though. Since it is set up "semi-permanently" so to speak, what are the chances that it will "settle" and need to be re-leveled and restabilized? I recently noticed that when someone walks through the TT, it's bouncing (if that is the term I can use?). I realize that this is not a secured, tied down structure like a modular home, and that there will be some give and take with the stability, but when I am laying in bed reading and someone walks through, I feel like I am on the road! Very noticeable to the point that it is getting irritating! Would it help to relevel/resecure the place? It is not on a concrete pad, just dirt and gravel areas, and we have had a great deal of rain this summer in the area. Any suggetions would help! TIA!
tchrmom77 is offline   Reply With Quote
Old 07-26-2019, 07:40 PM   #2
What do you have under the stabs, wheels and front jack?
hshaynes is offline   Reply With Quote
Old 07-27-2019, 03:10 PM   #3
My brother and son set it all up - what I can see is flat concrete squares as a base, then concrete blocks and wooden pieces between the ground and the stabilizer jacks. the jacks are not fully extended, so I'm guessing that would not be the issue? I am not at the site at the moment, but can send pictures in a few days.
Old 07-27-2019, 03:29 PM   #4
Take some pics if you will. Sounds as though there has been some settling during wet weather. Could also be the blocks are too small. We will see.
Old 07-27-2019, 04:51 PM   #5
Blackrock's Avatar
We are staying three months in an RV resort that has a lot of rigs set up full time. Most have Xchocks and additional screw jacks to augment the regular jacks.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-30-2019, 07:57 PM   #6
NWVIBE272's Avatar
+1 for x-chocks - they help stabilize a great deal. Donít over tighten and damage tires tho!
NWVIBE272 is offline   Reply With Quote
